help with invoicepdf.tpl
kb12345
recently WHMcs changed VAT numbers to a separate columns(tblclients.tax) and it broke our custom invoicepdf.tpl
I went ahead and added the following line to invoicepdf.tpl
if (array_key_exists('tax_id', $clientsdetails) && $clientsdetails['tax_id']) {
$pdf->Cell(0, 4, $clientsdetails['tax_id'], 0, 1, 'L');
now VAT number is shown but not in same location as before
VAT number is shows now, but in wrong format. It shows the following:
Invoiced To
USERNAME
ADDRESS
FR111111111
while it must be like following
USERNAME
ADDRESS
VAT Number: FR111111111
NOTE: There must be <br> after address, and "VAT Number" before it shows the number.
Any insight how can we modify code to complete this ?
would have been slightly easier if you had posted your code, but if you say that you're using...
then you could change it to...
	$pdf->Ln(5);
	$pdf->Cell(0, 4, Lang::trans('tax.vatLabel') . ": " . $clientsdetails['tax_id'], 0, 1, 'L');
and that should show their tax details as you describe.
