Livehehelp Addon and CORS problem
Turcu
I wanted to do a question. I am using the Livehelp Module (Chatstack) and i have a problem for load the chat in the main website. I have this setup:
WHMCS and Addon: https://my.example.com
Main Site: https://www.example.com
When i add the livehelp script in the website, it doesn't work correctly because CORS policy.  If i leave it as default it says:
"No 'Access-Control-Allow-Origin' header is present on the requested resource"
But then if i set Access-Control-Allow-Origin to "https://www.example.com" in https://my.lomahost.com .htaccess, it works a few moments, but then another error come back:
"The 'Access-Control-Allow-Origin' header contains multiple values 'https://www.example.com, https://www.example.com'"
So, the script at some point, is adding header again and is duplicated but i can't know when and how because is encrypted....
Is there some way to fix it? Is possible to make the chat work int this way? I hava tried lots of options and ways without success.
Thank you,
regards.
I was able to fix the issue. Just in case someone has a similar problem, what I added:
Header always unset Access-Control-Allow-Origin
Before setting the header in the .htaccess. Important the always or doesn't work in my case.
Regards.
