YaZhok - Arkosia.fr Posted April 11, 2019 Share Posted April 11, 2019 Hi everybody ! I need help with WHMCS and its login system. After a client is created so account, it is impossible (with any theme) to connect. The only way to connect is to redo an order.... If you have the answer to this bug, I will take it willingly! Kind regards A. YaZhok 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted April 12, 2019 Share Posted April 12, 2019 another user with a seemingly nulled installation... 🙄 0 Quote Link to comment Share on other sites More sharing options...
YaZhok - Arkosia.fr Posted April 13, 2019 Author Share Posted April 13, 2019 20 hours ago, brian! said: another user with a seemingly nulled installation... 🙄 I intendnse in a shortimstth ie hat my litigaties 0 Quote Link to comment Share on other sites More sharing options...
YaZhok - Arkosia.fr Posted April 18, 2019 Author Share Posted April 18, 2019 So, how to fix this error ? Help me please 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted April 19, 2019 Share Posted April 19, 2019 20 hours ago, YaZhok - Arkosia.fr said: So, how to fix this error ? Help me please but if you have an invalid license (you still do) and have installed a nulled version of WHMCS, then that could be the cause of your issue... getting a valid license and doing a clean reinstall might be a solution. 💡 0 Quote Link to comment Share on other sites More sharing options...
YaZhok - Arkosia.fr Posted April 19, 2019 Author Share Posted April 19, 2019 Hi  0 Quote Link to comment Share on other sites More sharing options...
YaZhok - Arkosia.fr Posted April 19, 2019 Author Share Posted April 19, 2019 Hi I will soon buy the license (I'm just waiting for money from a litigation to do so) because I miss a little money! I come back to you for you enquire this this reproduced with a valid license! 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted April 20, 2019 Share Posted April 20, 2019 16 hours ago, YaZhok - Arkosia.fr said: I come back to you for you enquire this this reproduced with a valid license! don't forget, once you have a valid license, you can contact WHMCS support for help. 🙂 if you get your license directly from WHMCS - https://www.whmcs.com/support/ if you get your license from a reseller / host - https://www.whmcs.com/reseller-support/ 0 Quote Link to comment Share on other sites More sharing options...
