Validation Help
solidblueliquid
  • WHMCS Developer
You could look into using the ShoppingCartValidateCheckout hook-point for this: https://developers.whmcs.com/hooks-reference/shopping-cart/#shoppingcartvalidatecheckout
The products and configuration are stored in $_SESSION[‘cart’] so you could loop through those to ensure that your validation requirements are met. If they aren't, then you could return an error which would prevent the checkout process from completing.
