redirect issue with module links
I have a problem with a redirect (dns module) in my client area ... friendly index.php is enabled and when I enter the module link the page is shown for 1 sec. and redirects to the root (main website).
this happens even if I disable the htaccess ...
How can I allow these URLs?
https://www.mydomain.tld/clients/index.php?m=linodedns&action=(.*)
everything else works in the admin area ... only the client area makes trouble ...
unfortunately, the developer does not report anymore but I think it's probably due to the friendly index.php settings
DNS module:
https://github.com/srpurdy/WHMCS-Linode-DNS-Addon
  • WHMCS Technical Analyst II
This would generally suggest an issue with the addon itself. Please ensure it is enabled and properly configured as per the authors instructions under Setup > Addon Modules and it should work as intended. If it does not, I'd recommend contacting a developer of WHMCS addons for further assistance with debugging the customisation and see if they can correct it for you.
