alexei.lexx Posted December 13, 2007 Share Posted December 13, 2007 Hello. I investigate Cpanel/WHM and WHMCS now. Both are trial. I try to integrate them. I do everything how is described here http://v3manual.whmcs.com/display.php?id=29 But then I create a new package in WHMCS, it isn't created automaticaly in Cpanel/WHM. Please, help me to resolve this problem. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted December 13, 2007 Share Posted December 13, 2007 (NOTE: You must have root access for that to work) Do you have root access, or reseller access to WHM? If root, are you expecting WHMCS to create the package (it won't), or simply set up the account using that information (it should)? 0 Quote Link to comment Share on other sites More sharing options...
alexei.lexx Posted December 14, 2007 Author Share Posted December 14, 2007 In "Manage Servers" I have put root login and password and also Access Hash. WHM panel is openned from WHMCS admin panel. I want to create cpanel packages from WHMCS. But when I do this, I see no request in Cpanel access logs and no packages are created. 0 Quote Link to comment Share on other sites More sharing options...
joe123 Posted December 14, 2007 Share Posted December 14, 2007 are you trying to create packages or accounts? you can create accounts that use the packages that already created and exist in WHM . or creating accounts with individual variables from whmcs without using a package name. 0 Quote Link to comment Share on other sites More sharing options...
alexei.lexx Posted December 14, 2007 Author Share Posted December 14, 2007 Can I create cpanel packages from WHMCS? 0 Quote Link to comment Share on other sites More sharing options...
joe123 Posted December 14, 2007 Share Posted December 14, 2007 Can I create cpanel packages from WHMCS? NO , the packages you create in WHM , you can only use the package that is in WHM already. 0 Quote Link to comment Share on other sites More sharing options...
alexei.lexx Posted December 14, 2007 Author Share Posted December 14, 2007 Thank for answer! 0 Quote Link to comment Share on other sites More sharing options...
