bruno Posted April 18, 2018 Share Posted April 18, 2018 We are selling emoji domains (.ws and .to domains) however the emojis do not show up properly on customer invoices, on their Domains panel, or on the Admin's Order panel. I've added emojione (https://github.com/emojione/emojione/blob/master/INSTALLATION.md) to the theme's header file and have checked "enable IDN domains" in WHMCS settings. The system charset is utf-8. Can anyone shed some light on here please? ? Link to comment Share on other sites More sharing options...
brian! Posted April 19, 2018 Share Posted April 19, 2018 On 4/18/2018 at 12:39, bruno said: We are selling emoji domains (.ws and .to domains) however the emojis do not show up properly on customer invoices, on their Domains panel, or on the Admin's Order panel. I've added emojione (https://github.com/emojione/emojione/blob/master/INSTALLATION.md) to the theme's header file and have checked "enable IDN domains" in WHMCS settings. The system charset is utf-8. Can anyone shed some light on here please? ? IDN support in WHMCS is very limited, so I deeply suspect you're going to have to make modifications to the templates and/or use hooks to modify arrays to get this to work as you intend. Link to comment Share on other sites More sharing options...
