Problem with error 500
Hello, gentlemen.
I would like to apologize if you have posted my doubts in the wrong place.
I have noticed that my whmcs is giving 500 error and it is not only the same when I try to create a product group, access the servers, create products, the system automatically takes me to the administrative login page, after login the system I release the page that you can access, but when I make the change and click on create the same give the page with the message "can not meet this request at the time.
HTTP ERROR 500 "
Can it be?
How can I fix this?
I thank everyone.
6 hours ago, WHMCS ChrisD said:
Olá Wals Lima
Bem vindo a comunidade
Por favor, vá para Setup> Configurações Gerais> Outros, em seguida, marque Mostrar Erros e Erros de Log, em seguida, salve, volte para criar um grupo de produtos e verificar se há um erro, é possível que você tenha um módulo disparando esse erro.
- Hello, whmcs does not save anything already tried to do this see the apos try save is not able to meet this request at the moment.
HTTP ERROR 500 gave this
Hi @Walas Lima
Could you please add the following to your configuration.php file and see if this shows any errors, if it does not you would need to review your server logs for the error:
$display_errors = true;
20 hours ago, WHMCS ChrisD said:
Hi @Walas Lima
Hello, out
Fatal error: Uncaught exception 'WHMCS\Exception\ProgramExit' with message 'Invalid CSRF Protection Token' in /home/grupoopremi/public_html/core/vendor/whmcs/whmcs-foundation/lib/TokenManager.php:0 Stack trace: #0 /home/grupoopremi/public_html/core/vendor/whmcs/whmcs-foundation/lib/TokenManager.php(0): WHMCS\TokenManager->handleInvalidToken() #1 /home/grupoopremi/public_html/core/includes/functions.php(0): WHMCS\TokenManager->checkToken('WHMCS.admin.def...', NULL) #2 /home/grupoopremi/public_html/core/erp/configservers.php(0): check_token('WHMCS.admin.def...') #3 {main} thrown in /home/grupoopremi/public_html/core/vendor/whmcs/whmcs-foundation/lib/TokenManager.php on line 0
