What to hid products out of stock
Netedge
8 hours ago, Netedge said:
I am using "modern" template to show products on my WHMCS.
I want to hide products whenever it goes out of stock and show only available products. How can I do that?
in /templates/orderforms/modern/products.tpl, you could add an {if} statement after {foreach from=$products key=num item=product}
{if $product.qty gt 0 or $product.qty eq ""}
and add a closing {if} before the {/foreach}
9 hours ago, Netedge said:
Its not working for me. Can you please update this file and send it back to me?
if you wanted to just disable the "Order Now" buttons for out of stock products, you could just do this...
<div class="text-right">
	{if $product.qty eq '0' or $product.qty|strstr:'-'}
		<button class="btn btn-danger btn-lg" disabled> {$LANG.outofstock}
	{else}
		<a href="cart.php?a=add&{if $product.bid}bid={$product.bid}{else}pid={$product.pid}{/if}" class="btn btn-success btn-lg"><i class="fa fa-shopping-cart"></i> {$LANG.ordernowbutton}</a>
	{/if}
</div>
products.tpl
also, remember that the "Modern" hasn't been updated in years.
https://docs.whmcs.com/Standard_Order_Form_Templates#Depreciated_Order_Form_Templates
Quote
"Boxes" and "Modern" no longer receive updates and may not be compatible with the latest features. They are provided for legacy users only.
if you want to remove product blocks that are out of stock, it's probably going to be easier to write a hook to manipulate the array - otherwise, you'll have blank spaces... although just marking them as out of stock would be easier! :idea:
if you're going to use standard cart, forget the attached file.
13 minutes ago, Netedge said:
Also I would like to know where should I put the code of out of stock in this file?
change...
                                    <a href="cart.php?a=add&{if $product.bid}bid={$product.bid}{else}pid={$product.pid}{/if}" class="btn btn-success btn-sm" id="product{$product@iteration}-order-button">
                                    </a>
to the code in the thread below...
