Need help to add my own menus for logged-in and non-logged in users
Raj007
Hi Developers,
I'm working on WHMCS Installation and customization since last few weeks and struck at one point. I've to do changes to menus.
1. Before a user logs in the Menu has items like Home, Announcements, Knowledgebase , Network Status, Contact Us
I need to add my own menus like Home, Domains, Hosting, SSL & Contact US. Where do I change it in the code.
2. After Logged in the current menu on default WHMCS is fine to continue.
Any help with code samples and location to change would be much appreciated.
Thanks In Advance,
Regards
Raj
Hi Raj,
http://docs.whmcs.com/Client_Area_Navigation_Menus_Cheatsheet
there will be plenty of example hooks posted in these forums too - the chances are, whatever you want to do, a similar hook will have already been posted (or you could adapt it).
if you get stuck, just ask. :idea:
