kmm2908 Posted March 31, 2017 Share Posted March 31, 2017 After update to 7.1.12 all our hooks have stopped running. Anyone experienced the same or have any ideas what to check? Thanks in advance for any help. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted March 31, 2017 Share Posted March 31, 2017 Setup -> General Settings -> Other tick the display errors and hook debug mode and see if anything shows in the site or the activity logs that might be a clue... 0 Quote Link to comment Share on other sites More sharing options...
kmm2908 Posted March 31, 2017 Author Share Posted March 31, 2017 Brian thanks. Already done that and getting Hooks Debug: No Hook Functions Defined for hook points that do have hooks scripts. No php errors. These hooks were all running on 7.1.11, this happened since update to 7.1.12. Also see: Hooks Debug: Hook File: the hooks list has been mutated to NULL 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted March 31, 2017 Share Posted March 31, 2017 how did you update between 7.1.1 and 7.1.2 ? incremental patch, full or via the updater?? i'm assuming incremental - i'd be tempted to download the latest v7.1.2 full version and upload that... certainly re-upload the vendor folder again from the full release and see if that does the trick. 1 Quote Link to comment Share on other sites More sharing options...
kmm2908 Posted April 1, 2017 Author Share Posted April 1, 2017 how did you update between 7.1.1 and 7.1.2 ? incremental patch, full or via the updater?? i'm assuming incremental - i'd be tempted to download the latest v7.1.2 full version and upload that... certainly re-upload the vendor folder again from the full release and see if that does the trick. Was auto update. Found the problem, this entry was added to the config file: $disable_hook_loading = true; We didn't add that so trying to get confirmed if this was done as part of the auto update process and was never removed in error. Thanks again for your help Brian. 0 Quote Link to comment Share on other sites More sharing options...
