ar_77 Posted January 23, 2017 Share Posted January 23, 2017 hello dear friends; how can I do this action in whmcs that the users which have not confirmed their emails can not order services. for more secutity and avoid from duplicated users (someone who create multiple accounts)، we need email verification .which of course have activated this option is whmcs and for each registration the confirmation email is sending to the user.but confirm or not confirm does not effect of account of user and all user(confirmed and not confirmed) can take services. how can we prevent this subject that the user that has not confirmed his email can not order services? thank you 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted January 23, 2017 Share Posted January 23, 2017 take a look at the thread below for an action hook solution to your issue... https://forum.whmcs.com/showthread.php?114267-Limit-Access-For-Unverified-Accounts 0 Quote Link to comment Share on other sites More sharing options...
ar_77 Posted January 24, 2017 Author Share Posted January 24, 2017 take a look at the thread below for an action hook solution to your issue... https://forum.whmcs.com/showthread.php?114267-Limit-Access-For-Unverified-Accounts hello،thank you for your help I performed that instruction and uploaded it inside " /includes/hooks/ " directory Now what is the next step?what should I do to activate and use this function? thank you very much 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted January 25, 2017 Share Posted January 25, 2017 hello،thank you for your helpI performed that instruction and uploaded it inside " /includes/hooks/ " directory Now what is the next step?what should I do to activate and use this function? if you've uploaded the hook, and made any changes to it's configuration to suit your needs, it should already be active. e.g if email verification is enabled in your settings, and you have a client who hasn't verified their email address, they will not be able to checkout an order until they verify the email address - they can add products/domains etc to the cart, but they can't checkout. 0 Quote Link to comment Share on other sites More sharing options...
