Overriding whois data does not work.
ozgurerdogan
I assume this was a new registration through WHMCS and not a transfer?
http://docs.whmcs.com/Domains_Tab#Default_Contact_Details
Specify which details will be displayed in the whois database for domains registered through WHMCS upon initial registration (registrar module permitting). The client's details will always be used as the registrant contact, ticking Use Clients Details will use their details for all other contacts. But by unticking this option and entering your details in the fields beneath these will be used as the Billing, Admin and Technical contacts instead. Clients will be able to change this via their client area later.
