Adham Posted November 12, 2016 Share Posted November 12, 2016 Hello, I'm installing my WHMCS on my server and I connected it with a new database successfully and I added the admin username of the WHMCS then I got this error although I'm sure that the username and password of the database are correct. How can I solve this issue ? Unable to complete incremental updates: Unable to import the 3.6.2 database file. Unable to import /home/nginx/domains/sub.domain.com/public/resources/sql/upgrade362.sql: SQLSTATE[42000]: Syntax error or access violation: 1142 INDEX command denied to user 'dbusername'@'localhost' for table 'tblaccounts' Thanks a lot 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted November 12, 2016 Share Posted November 12, 2016 for anyone else reading the thread, the solution was in the thread below. https://community.centminmod.com/threads/whmcs-installing.9464/#post-39972 0 Quote Link to comment Share on other sites More sharing options...
