AffordableDomainsCanada Posted June 23, 2016 Share Posted June 23, 2016 I am trying to install a Refer a friend module, and its asking me to install the following code;  Add following lines in templaes/{your-template}/header.tpl file  {php} if(isset($_GET['uid']) && $_GET['uid']!='') { $_SESSION['referrer'] = base64_decode($_GET['uid']); } {/php}  just after below lines of code  {$headeroutput}  But when I add  {php} if(isset($_GET['uid']) && $_GET['uid']!='') { $_SESSION['referrer'] = base64_decode($_GET['uid']); } {/php}  it breaks my website, im guessing it is NOT compatable with WHMCS 6.3.1, can someone help me make that little snipit of code compatable with 6.3.x 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted June 23, 2016 Share Posted June 23, 2016 do you have {php} tags enabled in your settings?  http://docs.whmcs.com/Security_Tab#Allow_Smarty_PHP_Tags  The use of {php} tags is depreciated in WHMCS v6 and above, but legacy support can be enabled here during a transition period. We recommend keeping this option disabled unless specifically required. I would suspect that they won't remove the option until v7 is released, so you should be ok for the rest of the year at least. 0 Quote Link to comment Share on other sites More sharing options...
