Problems with how to make "Country" optional on checkout
In the Modern orderform, is there a way to make the "Country" optional in viewcart.tpl?
I am trying to force a hidden choice for users in this way:
<select name="country" id="country" value="US" selected="selected">
But that still shows an error message: Please choose your country from the drop down box
If there is no way to make Country optional, is there a way I can make a hidden selection for the user?
this is how you have to make it
<input type="hidden" name="country" value="US">
but you will need to change countries select element name to something else, so it will not override/conflict with the hidden value
Thanks for your advice. What happens if I just delete that entire block:
   <label for="country" class="control-label">{$LANG.clientareacountry}</label>
                               <select id="country" name="country" class="form-control">
                                   {foreach from=$countries key=thisCountryCode item=thisCountryName}
                                       <option value="{$thisCountryCode}" {if $thisCountryCode eq $clientsdetails.country}selected="selected"{/if}>{$thisCountryName}</option>
                                   {/foreach}
                               </select>
If I delete that block and use
it still says I need to make a selection. So then I try to force it like
<input type="hidden" name="country" value="US" selected>
but it still says I need to make a selection. Is this what you mean?
Ok I solved it. A pain in the butt. I've been using WHMCS for 4+ years and I remember 4 years ago having this same issue with "Country" not being optional.... why take so long to make this optional?
Here's how I solved it by removing some code and changing things around:
<!--<select id="country" name="country" class="form-control">
                                       <option value="US" selected="selected">United States</option>
                               </select>-->
  • 1 year later...
                               </select>-->
Hi can you tell me what is that other things you do, because when i apply this make me mess in template.
