Nominet problem
JUH
We've got a problem with Nominet and changing name servers via WHMCS. We recently moved the billing system to a new server.
The e-mail being sent to Nominet is blank.
The keys are present and accounted for, gnupg is also installed.
As the code is closed source we're not able to take a look to see how its trying to sign the message.
Anyone experienced this before?
see the other Nominet threads, it will either be a permissions or ownsership problem with your setup.
if the email is blank, then the *most* likely issue is you have not set the permissions on the whmcs/modules/registrars/nominet/tmp directory
as a failed signing will include the unsigned version
It was nothing to do with permissions.
Problem with the environment paths for PHP. It wasn't able to find the gnupg binary, a simple symlink resolved it.
