Navigation Var in WHMCS for logged user issue - NEED help
rezabagh
hello
i use the bellow hook for adding a menu when user is not logged in , and it works fine , but now i need a hook to add a menu for users which are logged in , how should i edit this hook to get the result ?
NEED your help
Thanks
<?php
#adding Menu Item to primaryNavbar
use WHMCS\View\Menu\Item as MenuItem;
add_hook('ClientAreaPrimaryNavbar', 1, function (MenuItem $primaryNavbar)
$client = Menu::context('client');
// only add menu item when no client logged in
if (is_null($client)) {
$primaryNavbar->addChild('test')
->setUri('test.php')
->setOrder(10);
if the user is not logged in, the hook below will create a "test" navbar item; if they are logged in, it will show "test2"...
<?php
->setOrder(10);
// only add menu item when client logged in
if (!is_null($client)) {
$primaryNavbar->addChild('test2')
->setUri('test2.php')
->setOrder(10);
