How to delete the parts of Sub-Account Permissions
Nyan
I want to delete the indication of the followings in Add New Contact page.
Sub-Account-Permissions
Manage Domain Settings
View & Manage Affiliate Account
View & Modify Product Passwords
View Domains
I updated from V.6.1.1 to V.6.2.0.
WHMCS support told that I must look at the following URL.
http://docs.whmcs.com/Hooks:ClientAreaPageContacts
Any help would be greatly appreciated!!
there are probably two ways to do this - either by modifying the template(s), or using an action hook.
if you wanted to modify the templates, you could edit the clientareaaddcontact.tpl template and add an {if} statement to remove the permissions you don't want... replace the following code...
                {foreach $allPermissions as $permission}
                   <div class="col-sm-6">
                       <label>
                           <input type="checkbox" name="permissions[]" value="{$permission}"{if in_array($permission, $permissions)} checked{/if} />
                           <span>
                               {assign var='langPermission' value='subaccountperms'|cat:$permission}{$LANG.$langPermission}
                           </span>
                       </label>
                   </div>
               {/foreach}
with...
               {if $permission neq "manageproducts" and $permission neq "domains" and $permission neq "managedomains" and $permission neq "affiliates"}
                       <label>
                           <span>
                           </span>
                       </label>
                   </div>
               {/if}
               {/foreach}
additionally, you might need to make a similar change to 'clientareacontacts.tpl' which has a similar {foreach} loop to show the sub-account permissions.
or the quicker way, would be to use an action hook - add a file to the includes/hooks folder, call it "addcontactshook.php" and paste the following into it.
<?php
function hook_modify_accounts_permissions($vars)
       $permissions = array("allPermissions" => array("profile","contacts","products","productsso","invoices","quotes","tickets","emails","orders"));
       return $permissions;
add_hook('ClientAreaPageAddContact', 1, 'hook_modify_accounts_permissions');
the hook replaces the existing Smarty array with the options you want removed - with this, there should be no need to modify the templates.
