different currency and different payment method for specific product without default
crowlink
Hello;
I wanna use a currency and method for specific product and disable default currency for this product or group.
in other hands I wanna a product/group have their own currency/method other than default currency/payment methods?
is there any way disable default/other currency for this product?
Thanks
you should not set a price for that product in the default currency - though those using the default currency will not see the product.
if you want it to have it's own payment method, the easiest way would be to put it in its own product group and then define the payment methods for that group.
it is probably also worth noting that existing clients can only use one currency... so if they have already purchased a product in the default currency, they cannot purchase another product in a different currency - they must continue to use the default currency and you cannot/should not change it for them.... in those circumstances, they would need to create a new account.
