WHMCS cron job not running (or completed running?)
pdstein
I have another problem with WHMCS 6.
WHMCS' cron.php does not run via CPanel's Cron Job!
I have correctly updated the config/configuration files for the crons for the WHMCS 6. Also - If I accessed the cron.php via the browser - the WHMCS cron is able to successfully execute. (I know, cron.php should not be placed in a "public" directory, but just doing this for testing).
However, cron.php does not run (or maybe was not able to completely run) when configured from CPanel's cron. Cron job command is this:
php -q /home/myocc/public_html/crons/cron.php
I set an email address so an email will be sent when the cron runs - but strangely, I did NOT receive any emails. So I suspected that the cron did run - but just did not finish so email was not sent.
Note also that I created a TEST PHP script that will send a test email within the same directory as cron.php and the script ran successfully and email was sent.
Any ideas guys why?
Thanks again guys in advance!
you can set your email inside cron job page in cPanel
you may check activity log to see if the cron run and complete or it has any errors: Admin Area -> Utilities -> Logs -> Activity Log
hi sentq - yeah, i have set my email address in the cron job page in cPanel. however - it is NOT sending, so just wondering if the cron.php did NOT trigger in the first place. or probably was triggered, but did NOT complete.
checked WHMCS' activity log too - but no anomalies there. :-(
