biaprot Posted September 13, 2015 Share Posted September 13, 2015 Hello ! Currently I'm having trouble with problem viewcart page , it does a blank at the top of the page and i dont know how to fix this problem i'm try F12 to check and find and i see code: just delete it, then return to normal. I find in source and i dont see anything @@! Screenshot: 1 : I'm order services not problem 2 : Config product , not problem 3 : This problem @@! 4 : F12 and check 0 Quote Link to comment Share on other sites More sharing options...
nimonogi Posted September 13, 2015 Share Posted September 13, 2015 Provide the URL so we can review the source code and css files. 0 Quote Link to comment Share on other sites More sharing options...
biaprot Posted September 13, 2015 Author Share Posted September 13, 2015 hello ! this is link https://my.sampsv.net 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted September 13, 2015 Share Posted September 13, 2015 take a look at your viewcart.tpl template and see if it's being caused by something at the top of that. 0 Quote Link to comment Share on other sites More sharing options...
