Same registrar, different module
platongr
Recently, I installed the module that OpenSRS provides (domains pro 2.0.7) and seems that it is working. I used to have the one that whmcs had on a previous version.
Is there any way to update all domains that have as default registrar the "opensrs" to "opensrspro" ?
Thanks
you could use an SQL query to do it, e.g via phpMyadmin - but remember to backup the database before doing so.
update tbldomains set registrar = 'opensrspro' where registrar = 'opensrs';
I don't use the OpenSRS Domains Pro module, so first check the tbldomains database table and look at a domain already assigned to use the module and see what the registrar setting is... i'm guessing it's just 'opensrspro', but you should check that it is before running the query.
