Add products Detail in Homepage
hebergeni
I need to add this code in hompage.tpl but nothing is showing up
<div class="block-s2">
<!--Pricing Tables-->
<div class="row">
{foreach key=num item=product from=$products}
<div class="col-lg-3 col-sm-6">
	<div class="pricing-table-3 {if $num == 1}active position-relative{/if}">
		<h3>{$product.name}</h3>
		<div class="rate">
			{if $product.bid}{$LANG.bundledeal}{if $product.displayprice} {$product.displayprice}{/if}
			{else}{if $product.pricing.hasconfigoptions}{$LANG.startingfrom}:<br />{/if}
			{if $product.paytype eq "free"}
				<label class="label label-success label-xlg arrowed-in-right arrowed-in">{$LANG.orderfree}</label>
			{elseif $product.paytype eq "onetime"}
			<div class="price">
				<div class="amount">
					{$product.pricing.onetime}
				</div>
				<br /><label class="label label-success label-xlg arrowed-in-right arrowed-in">{$LANG.orderpaymenttermonetime}</label>
			</div>
			{else}
			<div class="price">
				<div class="amount">{$product.pricing.minprice.price}</div>
				<div class="term"><br />{if $product.pricing.minprice.cycle eq "monthly"}{$LANG.orderpaymenttermmonthly}{elseif $product.pricing.minprice.cycle eq "quarterly"}{$LANG.orderpaymenttermquarterly}{elseif $product.pricing.minprice.cycle eq "semiannually"}{$LANG.orderpaymenttermsemiannually}{elseif $product.pricing.minprice.cycle eq "annually"}{$LANG.orderpaymenttermannually}{elseif $product.pricing.minprice.cycle eq "biennially"}{$LANG.orderpaymenttermbiennially}{elseif $product.pricing.minprice.cycle eq "triennially"}{$LANG.orderpaymenttermtriennially}{/if}</div>
			</div>
			{/if}
			{/if}<br />
		</div>
		{if $product.featuresdesc}<div class="desc">{$product.featuresdesc}</div>{else}{/if}
		<ul>
			{foreach from=$product.features key=feature item=value}
				<li>{$value} {$feature}</li>
			{/foreach}
		</ul>
		{if $product.qty!=""}<small><em>({if $product.qty eq "0"}{$LANG.outofstock}{else}{$product.qty} {$LANG.orderavailable}{/if})</em></small>{/if}<br />
		<button type="button" value="{$LANG.ordernowbutton}"{if $product.qty eq "0"} disabled{/if} onclick="window.location='{$smarty.server.PHP_SELF}?a=add&{if $product.bid}bid={$product.bid}{else}pid={$product.pid}{/if}'" class="btn {if $num == 1} btn-success {/if}btn-primary" />{if $product.pricing.hasconfigoptions}{$LANG.orderconfigure}{else}{$LANG.ordernowbutton}{/if} <i class="fa fa-chevron-right icon-on-right"></i></button>
		{if $num == 1}
		<div class="ribbon-wrapper">
			<div class="ribbon bg-success">-10%</div>
		</div>
		{/if}
	</div></div>
{/foreach}
</div>
Can you please help me
Thank you
