hostingbagus Posted August 1, 2015 Share Posted August 1, 2015 Hello, I keep getting this error when trying to upgrade to whmcs 6.0.1 from 5.3.14 Upgrade Failed A problem was encountered while attempting to apply the database schema updates. The error message returned by the update process was as follows: Unable to complete incremental updates: Unable to import the 6.0.0 Alpha1 database file. Unable to import /home/****/public_html/clientarea/resources/sql/upgrade600alpha1.sql: Table 'tblupdatehistory' already exists Any idea? I'm using php 5.5, latest ionloader and also innodb. Thank you. Best Regards. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted August 1, 2015 Share Posted August 1, 2015 i've seen a number of threads about this... perhaps the one below will help. https://forum.whmcs.com/showthread.php?102762-Error-during-upgrade-6-0-issues 0 Quote Link to comment Share on other sites More sharing options...
hostingbagus Posted August 1, 2015 Author Share Posted August 1, 2015 i've seen a number of threads about this... perhaps the one below will help. https://forum.whmcs.com/showthread.php?102762-Error-during-upgrade-6-0-issues Yes I saw this thread earlier before posting. However the issue I'm having here seems to be during the installation/upgrade to 6.0.1 is in just under 1 minute before the installation finish. The request timed out. Network Error (tcp_error) A communication error occurred: "Operation timed out" The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time. For assistance, contact your network support team. I even tried to do a clean install on a new database. It still does the same. Never had this sort of issue before with 5.3.12 to 5.3.14 Since the install corrupted before even finish, I can't re-install it again. When I tried to reinstall this error appears: Unable to complete incremental updates: Unable to import the 6.0.0 Alpha1 database file. Unable to import /home/****/public_html/clientarea/resources/sql/upgrade600alpha1.sql: Table 'tblupdatehistory' already exists I have also tried to drop the following tables above. Didn't help it at all. Interestingly when I tried installing whmcs 6.0.1 using softaculous it works great! Installed in just 1 minute. The only problem now is how do I restore to the old database? I tried to overwrite the fresh installed database with the old backup. But then whmcs stopped working and this error appears: Down for Maintenance (Err 2) An upgrade is currently in progress... Please come back soon... Looks like I really need to do the incremental upgrade to properly restore the database, which is impossible to do no matter how many attempt I have tried. Any suggestions will help! Much Appreciated. Thanks! 0 Quote Link to comment Share on other sites More sharing options...
jcncnc Posted August 5, 2015 Share Posted August 5, 2015 I too would like to know how to restore the old database if you have to do a fresh install of the new database. 0 Quote Link to comment Share on other sites More sharing options...
Prohost4u Posted August 5, 2015 Share Posted August 5, 2015 I had the same issue. and i did read some wear that the V5 database is not the same as the new v6.1 so it will not work. i have even tried to just sql the client table into the new V6 data base and you get errors. so a full new install of V6 and then you have to set it up from scratch. If any one finds out if you can get a V5 data base to work on V6.1 let me know. 0 Quote Link to comment Share on other sites More sharing options...
HLZscot Posted August 5, 2015 Share Posted August 5, 2015 I had same issue updating to V6.0.1.. Tried all kinds of variations of clean installs vs copying over existing. The issue is PHP timeout is stopping the update. I had to increase the PHP execution time to over 2 minutes before the update would complete. And I timed it. It took right at 2 minutes. IMPORTANT! But it will only work on a database that has not had the update tried on it. So this is what I did. I uploaded whmcs files to a clean folder on my host. Restored old data base that had NOT had the upgrade tried on it. (you should have a backup prior to starting the upgrade) Ran update. Update finished, no issues. Then set PHP timeout back to 30 secs. 0 Quote Link to comment Share on other sites More sharing options...
