Problem with Project manager after v6 upgrade / Timeformat
Spear1976
After the recent upgrade to WHMCS v6.x, I've had an annoying issue with the project manager. Before the update i used 24 hour format, but after the update i can still type 24h format, but the time as automaticly adjusted to 12h format. Eg if i type start 16.00 and save, it's changed to 04.00.
Anyone else seen this or have a good solution for fix? :)
  • 1 month later...
Hva you reported the bug with whmcs. They promised it would be fixed. My clients are upset, because all my times are off on the reports.
WHMCS support told us today that the update 6.0.2 would fix the issue - but they were Wrong :(
We tried manually typing it in and it always resets to the wrong time now.
Hopefully they have another release soon!
  • 3 weeks later...
I think, according to the release notes, this has been fixed in v6.1.0RC1
http://docs.whmcs.com/Version_6.1.0_RC_1_Release_Notes
ADDON-5968 - Use 24 Hour Clock in Project Management Time Picker
also, the Letter size issue is fixed too.
CORE-8900 - PDF Letter Size Setting Non-Functional
however, as this is only a Release Candidate, I imagine that it may still be many weeks/months before a full release for production use.
