Adwords conversion tracking code is not working
EstebanC
is the integration code set correctly?
many WHMCS users here in forum did the integration before, most of them had the same issue "how to integrate it".
in complete.tpl file you need to place your Javascript code between these lines
{if $ispaid}
<!-- Enter any HTML code which needs to be displayed once a user has completed the checkout of their order here - for example conversion tracking and affiliate tracking scripts -->
{/if}
but in TPL files you need to wrap you Javascript codes with the Literal tag, so the final should look like this
{if $ispaid}
{literal}
<script type="text/javascript">
// My Tracking Code is right here
</script>
{/literal}
{/if}
also you need to integrate your tracking code into all of your templates
  • 5 years later...
