guru4hom Posted November 8, 2014 Share Posted November 8, 2014 I Installed a new theme called flathost Added new products but they didnt show up on the order page. Please help me, I'm new to this 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted November 8, 2014 Share Posted November 8, 2014 if this is a theme issue, it might be easier to contact the author directly. http://themeforest.net/item/flathost-responsive-hosting-template-with-whmcs/5043574 0 Quote Link to comment Share on other sites More sharing options...
guru4hom Posted November 8, 2014 Author Share Posted November 8, 2014 if this is a theme issue, it might be easier to contact the author directly. http://themeforest.net/item/flathost-responsive-hosting-template-with-whmcs/5043574 Thanks Brian, I have been speaking with the author and I don't think its a theme issue, I selected the default theme and still had the same problem 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted November 9, 2014 Share Posted November 9, 2014 you could try emptying the template cache and see if that fixes it... http://docs.whmcs.com/System_Utilities#Empty_Template_Cache Empty Template Cache WHMCS caches templates into static files to reduce the loading time of each page. In order for template changes to take effect it is necessary to clear the cached files. In order to do this one should remove all existing files from the templates_c folder which you can do quickly and easily using this option. Please ensure the /templates_c directory is writeable so that WHMCS is able to delete the cache files and generate new ones. the easiest way to do this is via the admin area... Utilities -> System -> System Cleanup -> Empty Template Cache 0 Quote Link to comment Share on other sites More sharing options...
