Display custom product field in admin panel
rizhiy87
Hi all. I have a task to import products from another system to WHMCS. So I need to store ID from source system.
We decided to use product custom field for this, but found out that we can not see custom field value in admin panel.
Question is: how can I see what custom field's value is? The best way is to display it on product summary tab, but looks like its impossible to change template.
Or maybe you can advice another way to store extra data for product (like externalID)?
