please help problems whmcs
dugarteae
Antonio,
I think you might have errors in your email template... such as using $ service_suspension_reason instead of {$service_suspension_reason} or $ service_domain instead of {$service_domain}
you should edit your template and click on the merge field links at the bottom when you want to add a merge field to your email template.
