adding a page between product selection and passing parameters between steps
mobasher
we are developing an add-on that get variables/input from customer when he/she do choosing product/services. so we need to get several input from client. i search the sites and find nothing on this topic.
how can i add the page after product selection. and passing parameter between them.
any help will be appreciated
Best regards
there was a reply a while back from one of the whmcs guys that you can't insert additional pages into the ordering process - you can tweak what's already there, bypass config etc - but can't change their order.
it might be a better solution to use Custom Fields to obtain the info you require from the client.
http://docs.whmcs.com/Custom_Fields
