Developer required for provisioning module - asap
Hi there;
I need someone that knows hes ways around WHMCS to write a custom provisioning module for me.
It will have basic operations:
- Create
- Update
- Terminate
The is available in both, json and xml and is well documented.
You may test the module on your own WHMCS installation. I will provide a demo account on the api.
I need this done ASAP.
Thanks in advance;
