minadreapta Posted November 23, 2012 Share Posted November 23, 2012 Hello, what i want to to is basically this: i want all the domain names in my whmcs that have: - extension is ".tld" - registrar is "email" - status is "active", "cancelled" or "expired" - expiration date is like "2012-mm-dd" if the above conditions are fulfilled, to move the expiration date from 2012-mm-dd to 2212-mm-dd (2 hundred years in the future). is this possible? thanks. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS JamesX Posted November 25, 2012 Share Posted November 25, 2012 (edited) You can use the following as a starting point and modify as per your own needs. SELECT id FROM `tbldomains` WHERE `domain` LIKE '%.tld' AND `registrar` = 'email' AND `expirydate` BETWEEN '2012-01-01' AND '2012-12-31' AND `status` IN ('Active', 'Expired', 'Cancelled') You can use DATE_ADD to figure out what the new dates should be. DATE_ADD(expirydate, INTERVAL 200 YEAR) Try this... SELECT id, DATE_ADD(expirydate, INTERVAL 200 YEAR) AS NewExpiryDate FROM `tbldomains` WHERE `domain` LIKE '%.tld' AND `registrar` = 'email' AND `expirydate` BETWEEN '2012-01-01' AND '2012-12-31' AND `status` IN ('Active', 'Expired', 'Cancelled') Edited November 25, 2012 by WHMCS JamesX 0 Quote Link to comment Share on other sites More sharing options...
minadreapta Posted November 25, 2012 Author Share Posted November 25, 2012 that worked like a charm. thanks a lot. 0 Quote Link to comment Share on other sites More sharing options...
