amico Posted August 8, 2007 Share Posted August 8, 2007 I am trying to combing My Products & Services and My Hosting Packages into one page basically because they are considered one category in my opinion. However, copying the contents of one file into another showed no logic results. (each template page cannot recognize the contents of other template and it nearly duplicates itself) Does any one know a workaround to do that? 0 Quote Link to comment Share on other sites More sharing options...
amico Posted August 11, 2007 Author Share Posted August 11, 2007 I am trying to combing My Products & Services and My Hosting Packages into one page basically because they are considered one category in my opinion.However, copying the contents of one file into another showed no logic results. (each template page cannot recognize the contents of other template and it nearly duplicates itself) Does any one know a workaround to do that? To be specific, with hope to get an answer, when I add up the contents of clientareahosting.tpl to clientareaproducts.tpl, the hosting table repeatedly enlist the product items instead of hosting packages. My guess is that the {$account.product} (which exists in both templates but show different entries when separate) is linked to the template title in some sort. Once again, does anyone know a workaround for this problem ... or a way to successfully combine both files. 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted August 11, 2007 Share Posted August 11, 2007 I am trying to combing My Products & Services and My Hosting Packages into one page I'd like to see the same, just split on the page between the various product types 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted August 11, 2007 WHMCS CEO Share Posted August 11, 2007 I would think this is only possible if I made a change inside the clientarea.php file for you. Matt 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted August 11, 2007 Share Posted August 11, 2007 I would think this is only possible if I made a change inside the clientarea.php file for you. That explains why merging the templates doesnt work 0 Quote Link to comment Share on other sites More sharing options...
amico Posted August 12, 2007 Author Share Posted August 12, 2007 I would think this is only possible if I made a change inside the clientarea.php file for you. Matt Don't worry about it Matt for now. It is not a priority for me, and I know you have a lot of things to do. However, you might want to consider it in future versions -if it makes sense and everyone else agrees- since hosting packages are themselves a type of product. Apart from that, keep up the good work. I am still impressed with whmcs ever since I installed it 0 Quote Link to comment Share on other sites More sharing options...
