dimitris Posted March 4, 2011 Share Posted March 4, 2011 Hi i had whmcs version 4.4.1 and suddenly i faced a strange problem .. all the tabs where open horizontal . For example if i press general ... instead of having only the first tab open i see all the tabs open one after the other. After that i decided to upgrade but now i saw that after uploading the files in WHMCS folder ... When i went from my browser to the admin link of whmcs in order to proccedd with the upgrade i saw a message to delete the installation folder as the installation was already been done. I believe that something is not working. Can you please help me figure this out ?? Thanks 0 Quote Link to comment Share on other sites More sharing options...
dimitris Posted March 4, 2011 Author Share Posted March 4, 2011 I solved the problem with the tabs..Buti have still a problem with the process of Upgrade When i Upload the files and go to admin area i get this message: Security Warning The install folder needs to be deleted for security reasons before using WHMCS Is this correct or i shall get the message to install the update as i saw in the previous update ?? Thanks 0 Quote Link to comment Share on other sites More sharing options...
bear Posted March 5, 2011 Share Posted March 5, 2011 I solved the problem with the tabs. Perhaps you could share the solution, so the next person to see it won't be frustrated by finding only "I fixed it"? The install folder needs to be deleted for security reasons before using WHMCSIs this correct or i shall get the message to install the update as i saw in the previous update ?? I'd received the same thing, but it appears to have updated properly. I would assume it was minor enough that it simply happened very quickly on access, and no user input was needed. 0 Quote Link to comment Share on other sites More sharing options...
dimitris Posted March 8, 2011 Author Share Posted March 8, 2011 Sorry that answers "i fixed it" are very annoying for me too. The tab problem was occured because i have trigered the file jquery.js in /includes/jscript whaen i replaced it with the original the problem fixed. 0 Quote Link to comment Share on other sites More sharing options...
