Need Help Fixing Footer
CFulcrum
My footer does not display properly in my WHMCS client area. I need it to look the same as it does on my homepage and all of the pages outside of the whmcs.
I realize it has something to do with a <div> tag somewhere, but I have tried for hours to fix it and I can't find it.
<<snipped>>
"#footerimages"
You need to set a negative margin, I believe, though that still won't get it inside that black bar, so the div that contains it needs to be a bit taller.
Use Firefox browser, with the Firebug plugin installed. You won't regret it. ;)
This nearly does it:
#footerimages  {
float:right;
margin:-20px;
padding:0 20px 0 0;
If you also made the copyright div 100% wide, black (or whatever color that is) and used padding instead of margin to offset it from the right side, that would likely fix it.
Div positioning is done via CSS, so how is that cheating, exactly?
The way you have it right now, change the height on footerlinks to 110 from 90px; done.
#footerlinks {
background-color:#000000;
background-image:url("images/footer_nav.png");
background-position:left top;
background-repeat:repeat-x;
float:left;
height:110px; //change this
margin:0;
padding:8px 0;
text-align:left;
width:100%;
edit:
If you also change the padding on the copyright bit, it will line up with the images above it.
#copyright {
color:#CCCCCC;
float:right;
font-size:10px;
margin:0 5px 0 0;
padding:0 20px 0 0; // change this
text-align:right;
Result:
