chrismfz Posted August 21, 2010 Share Posted August 21, 2010 When I am trying to whois a domain from client side or admin side it doesn't matter like .gr .es .tk .co.za .za.net etc I get no output. More specific, in includes/whoisserves.php every TLD which has this URL format: .co.za|http://whois.co.za/cgi-bin/whois.sh?Domain=|HTTPREQUEST-No Matches .org.za|http://org.za/cgi-bin/rwhois?format=full&domain=|HTTPREQUEST-Domain not registered .tk|https://partners.nic.tk/cgi-bin/whmcs-whois.taloha?d=|HTTPREQUEST-has no matches .es|http://www.realtimeregister.com/page/whois_check.php?domein=|HTTPREQUEST-es available .com.ph|http://www.domains.ph/WhoIs.asp?Domain=|HTTPREQUEST-no match .net.ph|http://www.domains.ph/WhoIs.asp?Domain=|HTTPREQUEST-no match .org.ph|http://www.domains.ph/WhoIs.asp?Domain=|HTTPREQUEST-no match .ngo.ph|http://www.domains.ph/WhoIs.asp?Domain=|HTTPREQUEST-no match .ph|http://www.domains.ph/WhoIs.asp?Domain=|HTTPREQUEST-no match .za.net|http://www.za.net/cgi-bin/whois.cgi?domain=|HTTPREQUEST-No such domain .za.org|http://www.za.net/cgi-bin/whois.cgi?domain=|HTTPREQUEST-No such domain it doesn't work. I get an empty output. Does anyone has the same problem with those TLD's ? Any other TLD's with normal whois servers like .com|whois.crsnic.net|No match for .net|whois.crsnic.net|No match for .org|whois.publicinterestregistry.net|NOT FOUND .co.uk|whois.nic.uk|No match they are working. 0 Quote Link to comment Share on other sites More sharing options...
chrismfz Posted August 21, 2010 Author Share Posted August 21, 2010 Someone with 4.3 please take a look if you can whois domains ending with tld like .es .co.za .tk etc... Support didn't respond for 12+ hours and I don't know if it is a general 4.3 bug or its just me 0 Quote Link to comment Share on other sites More sharing options...
ljesh Posted August 22, 2010 Share Posted August 22, 2010 I have similar issue since 4.3 with another TLD (.mk) The whois check is not in the whoisservers.php but I have added it manually for that TLD. Until 4.2 used to work perfect, now for every domain with .mk extension it says the domain is already taken (which ofcourse, isn't the case). .com, .net.... whois works good. Opened support ticket, will see how it goes from there. 0 Quote Link to comment Share on other sites More sharing options...
webio Posted August 25, 2010 Share Posted August 25, 2010 I'm having similar issue with my WHOIS response. I'm also using custom whois server provided by my registrar. Have you received reply for your ticket? 0 Quote Link to comment Share on other sites More sharing options...
ljesh Posted August 25, 2010 Share Posted August 25, 2010 Yes, they sent me a new whoisfunctions.php and it works from then. Will try to upload it (though, I don't know if I am allowed to do so ) 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted August 25, 2010 Share Posted August 25, 2010 No problem doing whois lookups on a .co.za domain that I tested. 0 Quote Link to comment Share on other sites More sharing options...
webio Posted August 29, 2010 Share Posted August 29, 2010 (edited) Ok I have updated whoisfunctions.php and it looks ok for registration but for transferring .com domains I'm stil getting Unavailable status. Can someone confirm the same problem during omain transfer action? EDIT: I've also noticed that after replacing whoisfunctions.php file I can enter google.com for registration and WHMCS states that this domain is available. I'm using default WHOIS server for .com TLD. EDIT2: This is quite interesting because even when I set custom WHOIS server for .com TLD and I know that this custom WHOIS server is returning that this domain is unavailable WHMCS is anyway returning that this domain is available for registration. Edited August 29, 2010 by webio 0 Quote Link to comment Share on other sites More sharing options...
