Problem with Charset
agustin
Anybody found another easier solution?
I also have this charset issue. My WHMCS is running with ISO-8859-1 and I rarely get mess up e-mails but sometimes I get, depending of the client.
But one annoying thing is that I can't edit answers on the ticket log, it saves in UTF-8.
Anybody knows if I can change the default chatset on the editor to ISO-8859-1, and if it would cause any other problem on the system?
Thanks!
Hi! Did you find any solution? I have exactly the same problem with Greek. My WHMCS is running with UTF-8 and the Greek characters in e-mails from Google apps Gmail come in ISO-8859-7.
In WHMCS administration when changing encoding from utf-8 to iso-8859-7 I can see the right characers instead of �
But the real problem is in the auto respond e-mail that a client receives when a ticket is opened, where the client receives some non readable characters instead of his e-mail text.
Thanks!
So, I think that the right solution would be to change the message and subject encoding in the database and have all messages in utf-8 encoding, as the WHMCS uses.
But i have tried http://www.php.net/manual/en/function.iconv.php http://de.php.net/manual/en/function.utf8-encode.php and http://de.php.net/manual/en/function.imap-utf8.php
and noone seems to give the solution.
Any suggestions? :?:
Thanks!
I hope they will find a solution quickly.
I used http://www.phpclasses.org/browse/package/1360.html and the test page is working! The Greek characters from the database appear as it should.
I will try later to make the hook also.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8" />
<title>Encode testing</title>
</head>
<body>
<?php
require_once "includes/ConvertCharset/ConvertCharset.class.php";
// Encode testing
mysql_connect('localhost:3304', 'user', 'pwd');
mysql_select_db('dbname');
// Read first 5 tickets
$sql = "SELECT id, tid, title, message FROM tbltickets LIMIT 5";
$res = mysql_query($sql);
// For each ticket
while(list($id, $tid, $title, $message) = mysql_fetch_array($res)) {
   // Shows generic info for this ticket
   echo "[$id] ";
   echo "<strong>$title</strong><br />\n";
   echo "<p><strong>Before</strong><br />$message</p>\n";
   // Check if encoding is utf8
   $enc = mb_detect_encoding($message, "UTF-8, ISO-8859-7");
   if($enc!="UTF-8") {
			$Entities = 0;
			$FromCharset = $enc;
			$ToCharset = "UTF-8";
			$text = new ConvertCharset($FromCharset, $ToCharset, $Entities);
			$message = $text ->Convert($message);
	// and print fixed message
       echo "<p><strong>After $enc</strong><br />$message</p>\n";
   echo "<hr />\n";
</body>
</html>
  • 3 weeks later...
  • 3 months later...
  • 6 months later...
  • 5 months later...
Same problem here,
I try to print labels with Nicelabel and Labelview by using MyODBC driver and Nicelabel native MySQL support.
Same problem, all accents are destroyed.
If I use EMS MySQL Manager, a front-end, same result as I browse the DB.
WHMCS team, please reply ?
  • 6 months later...
  • 3 weeks later...
Matt once again to the rescue:
And for the charset issue on tickets, I'm suspecting there's some kind of issue with the PHP iconv library on your server causing this so please try adding the following line to your WHMCS configuration.php file and see if this helps at all.
$disable_iconv = true;
Worked like a charm! No more problem with funny characters on my tickets. :)
Thank you, Matt!
Thanks. Adding $disable_iconv = true; to configuration.php also fixed the issue for me. For several years I have had the problem with special characters that display wrong not readable. I am using iso-8859-1 in WHMCS. I have also asked Matt in support tickets years ago for help, but he did not have a solution. But this fixed it!
So I guess the rule will be that if you have iso-8859-1 in WHMCS, then you need to add this fix.
