SkGold Posted April 14, 2013 Share Posted April 14, 2013 It seems like version 1.0.0 doesn't properly work with WHMCS 5.2.3 I replaced Ispapi version 0.9.6 to 1.0.0 1. First of all, your README file doesn't tell how to upgrade so I deactivated module, removed all files from /modules/registrars/ispapi/ folder, upload new files, and activated module again. Is it correct way to upgrade or it need to do something special? 2. I am getting completely different look of configuration settings in the WHMCS Admin area under the Setup => Product/Services => Domain Registrars => Configure. Please see screenshot and compare it with the one that you have in your README file. Your README file says that I need to go to Setup => Domain Registrars => Registrar Settings, but actually I need to go to Setup => Product/Services => Domain Registrars => Configure 3. Also how the new _Sync method works? I am not getting any output notices for sync expiration/next due dates. So how do I know that everything is correct? Do I need to remove cron job for ispapisync.php? Thanks, Sergey 0 Quote Link to comment Share on other sites More sharing options...
hexonet Posted April 15, 2013 Author Share Posted April 15, 2013 Hi Sergey, re. 1, just overwriting the existing files would have worked, too. We will adjust the README accordingly, thx for the hint! re. 2, thank you, we will fix that in the README as well. re. 3, WHMCS introduced a new dedicated domain sync job. It needs to be set up, in addition to the admin cron job: http://docs.whmcs.com/Domains_Tab#Domain_Sync_Enabled Also, please disable the ispapisync.php, it's deprecated in favor of the new mechanism. Best, - jens 0 Quote Link to comment Share on other sites More sharing options...
hexonet Posted April 29, 2013 Author Share Posted April 29, 2013 New version available: 1.0.4 - fix for transfer sync - improved handling of invalid API responses - fix for contact updates using handles https://www.hexonet.net/files/whmcs/ispapi/README.pdf Full module can be downloaded here: https://www.hexonet.net/files/whmcs/ispapi/ispapi_whmcs-1.0.4.zip Best, -jens 0 Quote Link to comment Share on other sites More sharing options...
SkGold Posted February 8, 2014 Share Posted February 8, 2014 Hi Jens, Couple questions. Can we use HEXONET 1.0.4 module: 1. With WHMCS 5.3.3? 2. For new gTLDs such as .BIKE; .CAMERA; .COFFEE and all others? Or there will be a new module version? Thanks, Sergey 0 Quote Link to comment Share on other sites More sharing options...
hexonet-anthony Posted February 12, 2014 Share Posted February 12, 2014 Hi Sergey, re. 1: In order to be up to date you should install ISPAPI Registrar Module 1.0.9 and ISPAPI DomainChecker 0.5.1. re. 2: You can use our current module for the new gTLDs (only for GoLive), however we are working on a new concept, that will be available in a couple of weeks. Best, Anthony 0 Quote Link to comment Share on other sites More sharing options...
SkGold Posted March 16, 2014 Share Posted March 16, 2014 Hello, Upgraded to WHMCS 5.3.5 and ISPAPI Registrar Module 1.0.12 Now I am getting the blank page with the "Invalid Template Filename" error while clicking on the "WHOIS Privacy" link in the Management Tools section of a domain that got ID Protection enabled. Also getting the same error while clicking on the ".CA Registrant Whois Privacy" and ".CA Change of Registrant" links for .CA domains. Thanks, Sergey 0 Quote Link to comment Share on other sites More sharing options...
hexonet-anthony Posted March 17, 2014 Share Posted March 17, 2014 Hi Sergey, due to some security changes added by WHMCS 5.3 our ISPAPI Registrar Module was raising an "Invalid Template Filename" error. This issue has been resolved. New version (1.0.13) can be downloaded here: http://www.hexonet.net/files/whmcs/ispapi/ispapi_whmcs-1.0.13.zip Best, Anthony 0 Quote Link to comment Share on other sites More sharing options...
SkGold Posted March 18, 2014 Share Posted March 18, 2014 Thank you Anthony, it is working now. However on the ".CA Change of Registrant" page it is showing several fields twice (Legal Type, CIRA Agreement, and WHOIS Opt-out). Please see attached screenshot. Thanks, Sergey 0 Quote Link to comment Share on other sites More sharing options...
hexonet-anthony Posted March 18, 2014 Share Posted March 18, 2014 Hi Sergey, you have to delete the following lines of your "includes/additionaldomainfields.php": //### include dirname(__FILE__).DIRECTORY_SEPARATOR ."..".DIRECTORY_SEPARATOR ."modules".DIRECTORY_SEPARATOR ."registrars".DIRECTORY_SEPARATOR ."ispapi".DIRECTORY_SEPARATOR ."additionaldomainfields.php"; //### This configuration is deprecated. Best, Anthony 0 Quote Link to comment Share on other sites More sharing options...
SkGold Posted March 20, 2014 Share Posted March 20, 2014 Thank you Anthony. You may need to update your README file as it has outdated info. Another big problem is that the cron job updates all domains to the same Expiry and Due date. This makes a big mess with domains and invoices. Thanks, Sergey 0 Quote Link to comment Share on other sites More sharing options...
hexonet-anthony Posted March 21, 2014 Share Posted March 21, 2014 Hi Sergey, Thanks for the hint, we will update the README file. We have checked our sync function and it's working. WHMCS 5.3 released a lot of new things, you should check your WHMCS settings (e.g. Number of Days to Set Due Date in Advance of Expiry) Best, Anthony 0 Quote Link to comment Share on other sites More sharing options...
