stiller Posted June 18, 2010 Share Posted June 18, 2010 Hi guys, I provided Matt with some info on the VZAgent SOAP API. Credit where credit's due, I got the code from another Parallels user: http://forum.parallels.com/showthread.php?t=102062 Stopping/starting containers works for me on a VZ server. However, there is still a ton of work to be done for things like creating new containers, uploading templates, etc. The good news is, it doesn't use PVA (or PIM), so there is one less dependency to worry about. (as a host, we don't really use these apps) Maybe it would be nice to get the community on this? There's a programming guide here: http://download.swsoft.com/virtuozzo/virtuozzo4.0/docs/VZAgent_ProgGuide.pdf Regards, Joachim 0 Quote Link to comment Share on other sites More sharing options...
timgws Posted June 22, 2010 Author Share Posted June 22, 2010 Hey Joachim, The problem with the migration from PIM to PVA is that you are forced to also move to the newer version of VZAgent. This is where the issue with. We do not rely on PVA/PIM as a dependency, but we do rely on it's dependancy, which does need to be upgraded. The fact of the mater is this module still works if you stay on VZAgent 4.0. Stopping and starting containers still works if you move to VZAgent 4.5, but creating and upgrading containers stops working when upgrading to PVA 4.5/VZAgent 4.5. Regards, Tim 0 Quote Link to comment Share on other sites More sharing options...
timgws Posted July 14, 2010 Author Share Posted July 14, 2010 I have done quite a bit of work on some updated code. It is currently working for us on PIM 4.0 (We rolled back after Parallels giving us the run around, very frustrating!) What I will do is merge the updated code, write a document describing how to set it up and upload it here. Please expect this to be done in the next few days... 0 Quote Link to comment Share on other sites More sharing options...
freds Posted July 16, 2010 Share Posted July 16, 2010 Hi - we would like to participate in making this module more feature rich if possible. But to begin I'm curious on how to manage Plesk panel to be included or not on each VPS. We need to charge for the license and this needs to be added to the VPS. Can this be done in the creation process or do we need to manage this post-creation? I hope somebody can sheed some light on this topic. 0 Quote Link to comment Share on other sites More sharing options...
jclusso Posted July 17, 2010 Share Posted July 17, 2010 Any update on this? 0 Quote Link to comment Share on other sites More sharing options...
tophostingcenter Posted August 5, 2010 Share Posted August 5, 2010 Hi, Hope you can reply to this post asap. Right now we download your virtuozzo php zip and you mention that we have to run sql-queries.sql. But because our mysql server is not on the box as Whmcs, we cannot find this one. you will be kind if you can provide us the create statements as soon as possible Thank you in advance. Eric 0 Quote Link to comment Share on other sites More sharing options...
tophostingcenter Posted August 5, 2010 Share Posted August 5, 2010 Hi, I found sql-queries.sql finally through a post. Thanks eric 0 Quote Link to comment Share on other sites More sharing options...
Batu Posted August 29, 2010 Share Posted August 29, 2010 Hello, I have IP-Pool problem. I add the IP address but still gives error. "There are no IPs that have been added to the Virtuozzo module's IP Pool! Please click Add IPs to add some." 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted September 24, 2010 Share Posted September 24, 2010 Is this module still being actively developed, and does it work on the latest version? 0 Quote Link to comment Share on other sites More sharing options...
oscarenzo Posted October 5, 2010 Share Posted October 5, 2010 hello guys, so this module work? regards. 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted October 5, 2010 Share Posted October 5, 2010 It wasn't working for us. Since the developer seems to have abandoned it, I'm in the process of making it work again. 0 Quote Link to comment Share on other sites More sharing options...
tohms Posted November 20, 2010 Share Posted November 20, 2010 Any news on the module? 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted November 20, 2010 Share Posted November 20, 2010 I ended up modifying it to work with our setup. Once I have some time to polish it I'll release it to the public. 0 Quote Link to comment Share on other sites More sharing options...
tohms Posted November 20, 2010 Share Posted November 20, 2010 If you need a hand let me know as I'm strongly interested in such a module. Can you already tell which functionality will be included? 0 Quote Link to comment Share on other sites More sharing options...
urgentVPS-Bret Posted November 21, 2010 Share Posted November 21, 2010 laszlof said: I ended up modifying it to work with our setup. Once I have some time to polish it I'll release it to the public. Very interested in this, do let us know how you get on with it 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted November 23, 2010 Share Posted November 23, 2010 We're using it in production currently. All the usual create/suspend/terminate/etc functions are supported. Also, rather than using the annoying IP allocation they had coded into it, I modified it to dynamically allocate IP addresses using the built in virtuozzo pool in vz 4.x. It also has functions to support application template installs. We're currently only using this for cPanel installations, but It could be adapted to work with other things. At the moment, its highly-specific for our environment, and will need to be tweaked to be more general. I'll make a post once I have had time to work on it. 0 Quote Link to comment Share on other sites More sharing options...
chuckt101 Posted January 16, 2011 Share Posted January 16, 2011 laszlof, just curious if you've had time to work on this further? Thanks 0 Quote Link to comment Share on other sites More sharing options...
shotgun Posted March 4, 2011 Share Posted March 4, 2011 Hi, Any news on this? Thanks 0 Quote Link to comment Share on other sites More sharing options...
consc198 Posted May 4, 2011 Share Posted May 4, 2011 Is there any updates to this? We're looking to create our own WHMCS module but if there is one already we don't want to redo everything. 0 Quote Link to comment Share on other sites More sharing options...
xcellhost Posted October 13, 2011 Share Posted October 13, 2011 tophostingcenter said: Hi, I found sql-queries.sql finally through a post. Thanks eric Hi Eric, how to found sql-queries.sql? Thanks, 0 Quote Link to comment Share on other sites More sharing options...
xcellhost Posted October 13, 2011 Share Posted October 13, 2011 Hi All, I have successfully added Virtuozzo Server but failed to add IP Address in IP Address Pool from WHMCS. Also not getting any error. Thanks, 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted October 13, 2011 Share Posted October 13, 2011 hi, i have the same issue. 0 Quote Link to comment Share on other sites More sharing options...
msaunders Posted October 13, 2011 Share Posted October 13, 2011 I know its not free , but we are using this and it works very well. Guys are good to deal with also. Its worth a look. http://forum.whmcs.com/showthread.php?t=40555 0 Quote Link to comment Share on other sites More sharing options...
xcellhost Posted October 14, 2011 Share Posted October 14, 2011 Hi, Any one can help me on IP Address Pool issue? It is really appreciate. Thanks, 0 Quote Link to comment Share on other sites More sharing options...
xcellhost Posted October 15, 2011 Share Posted October 15, 2011 Hi, Any one can help me on IP Address Pool issue? It is really appreciate. Thanks, 0 Quote Link to comment Share on other sites More sharing options...
