umar Posted November 4, 2009 Share Posted November 4, 2009 Hi We are getting this error when we try to register a .uk domain. I have spoken to service provider and they said the oubound ports are open and they can't see why its not working we have a resellers account . Registrar Error Error: Connecting to ssl://epp.nominet.org.uk on port 700. The error message was '' (code 0) please could someone explain why this error code is happening thanks 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted November 5, 2009 Share Posted November 5, 2009 Error: Connecting to ssl://epp.nominet.org.uk on port 700. please could someone explain why this error code is happening You were unable to connect to epp.nominet.org.uk on port 700 obvious problems would be * firewall rules * incorrect nameservers * blocked by nominet 0 Quote Link to comment Share on other sites More sharing options...
harrip Posted November 5, 2009 Share Posted November 5, 2009 I am also getting this same error today. I have moved servers where WHMCS resides. I've notified Nominet of the new IP address associated with the server but still no joy. I've raised it with Nominet too. Which Nameservers do you think may cause this Rob? Cheers. 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted November 5, 2009 Share Posted November 5, 2009 can the machine resolve epp.nominet.org.uk (i.e. your local resolv.conf entries) ? did you compile php with curl/ssl support ? can you telnet to port 700 ? 0 Quote Link to comment Share on other sites More sharing options...
harrip Posted November 5, 2009 Share Posted November 5, 2009 Thanks Rob. Working through this now. I will advise where the problem was. Cheers. 0 Quote Link to comment Share on other sites More sharing options...
umar Posted November 5, 2009 Author Share Posted November 5, 2009 can the machine resolve epp.nominet.org.uk (i.e. your local resolv.conf entries) ?did you compile php with curl/ssl support ? can you telnet to port 700 ? I have tried everything nothing working ? My reseller acccount is on a shared server? do i need a dedicated server ? 0 Quote Link to comment Share on other sites More sharing options...
harrip Posted November 6, 2009 Share Posted November 6, 2009 Got mine fixed. I had registered the IP address with Nominet for the hosting account where WHMCS resides rather than the server gateway IP for all IP aliases. Could this be the same for you Umar? Thanks for the pointers Rob. 0 Quote Link to comment Share on other sites More sharing options...
umar Posted November 6, 2009 Author Share Posted November 6, 2009 Got mine fixed. I had registered the IP address with Nominet for the hosting account where WHMCS resides rather than the server gateway IP for all IP aliases. Could this be the same for you Umar? Thanks for the pointers Rob. Hi Harrip , Thanks for the feedback i have tried everything and stil hasn't worked so i am going to your suggestion now and i will post my findings. 0 Quote Link to comment Share on other sites More sharing options...
umar Posted November 6, 2009 Author Share Posted November 6, 2009 Harrip , i was using the wrong IP like yours i have got past that issue now i am getting An Error Occured Command syntax error When i try to register a domain. Thank you for your feedback btw it really helped and thanks to rest you for your help 0 Quote Link to comment Share on other sites More sharing options...
umar Posted November 7, 2009 Author Share Posted November 7, 2009 All sorted thank you for yoru help guyz 0 Quote Link to comment Share on other sites More sharing options...
