papas76 Posted September 12, 2009 Share Posted September 12, 2009 Hey everyone I have a question with my Imap pipe/pop a thing. I have my support dept setup and configured. I added the link in my cron. I also added the fowarder on my cpanel. I followed the documentation video so I know its setup correctly. Imap is installed on my reseller server but the problem is Im not getting the emails as tickets. Any ideas on what could be happening? You can forget about whmcs support they respond to me only when they feel like it. 0 Quote Link to comment Share on other sites More sharing options...
striddy Posted September 12, 2009 Share Posted September 12, 2009 You are using cpanel, so you have not followed the instructions correctly. Remove the cron command, use the forwarder instead. In cpanel > forwarders > add forwarder > type your support email address > pipe to a program > public_html/whmcspath/pipe/pipe.php WHMCS is in the UK so be aware of the time zone difference. 0 Quote Link to comment Share on other sites More sharing options...
papas76 Posted September 12, 2009 Author Share Posted September 12, 2009 Ok so I tried that but still nothing. I did not recieve a email at all nevermind a ticket. I can't figure out for the life of me what I did wrong. Thanks for your response. 0 Quote Link to comment Share on other sites More sharing options...
