brianbak Posted September 10, 2009 Share Posted September 10, 2009 Users can not log in unless they click the "remember me" box. Add to card will not add anything to the cart. Any help would be rgeat. 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted September 11, 2009 Share Posted September 11, 2009 check the session save path in your php.ini and also the permissions on the session_save_path directory 0 Quote Link to comment Share on other sites More sharing options...
brianbak Posted September 11, 2009 Author Share Posted September 11, 2009 my session.save_path is comented out. ;session.save_path = /tmp 0 Quote Link to comment Share on other sites More sharing options...
brianbak Posted September 11, 2009 Author Share Posted September 11, 2009 I uncomented it, made sure folder was 777, and restarted apache. Still same issue. 0 Quote Link to comment Share on other sites More sharing options...
brianbak Posted September 11, 2009 Author Share Posted September 11, 2009 got it. When I installed Vtiger it put in its own session.save_path in .htaccess Thanks for pointing me in the right direction. 0 Quote Link to comment Share on other sites More sharing options...
