Nominet Sync Problem
smurf
We've recently just got a Nominet TAG and transferred our domains across. But now after setting up the Nominet Module in WHMCS we're having a problem where for some reason the sync cron job will not update the expiry dates on domains.
To get the domain into WHMCS we've setup a domain as a new transfer order as the client, logged into the admin side and activated it and then run the cron.
The sync runs, we get an email confirmation but the expiry is not updated and is left as 00/00/0000.
The rest of the Nominet module works great. We can update nameservers / contact details with no problems.
Has anyone seen this issue before?
Thanks for the reply CSNM-Carl. I'm glad at least that it's not just us!
I've support ticketed this so perhaps the WHMCS guys can come up with a fix.
How do you update the domains then? Manually or via another script?
Edited by smurf
I had the same problem but downloaded the latest nominetsync file from the latest build within the client area and all works fine now...
Pjs32 I owe you a beer! :-P
Who knows what the exact issue is but after downloading the full 4.0.2 release and replacing /modules/registrars/nominet/nominetsync.php and /modules/registrars/nominet/nominet.php the sync now works and updates the expiry dates perfectly!
