silentace Posted June 21, 2009 Share Posted June 21, 2009 I have a good grasp on HTML/CSS but I don't know if there is an issue with the PHP or what. My background-position changes depending on what section you are in. Â http://client.surrealhosting.com/ Â If you go to each section the background position moves up or down. The CSS for body is below. Â body { background-image: url('http://www.surrealhosting.com/images/background.jpg'); background-position: center; background-repeat: no-repeat; background-color: #666; } Â I assume its something to do with the bottom divs or something along those lines... but not sure which one would effect it. Just trying to get the background to stay in one position so you don't see a change per page. 0 Quote Link to comment Share on other sites More sharing options...
mojowill Posted June 22, 2009 Share Posted June 22, 2009 try changing background postion to : top center 0 Quote Link to comment Share on other sites More sharing options...
BAJI26 Posted June 22, 2009 Share Posted June 22, 2009 (edited) Try Fixed position. Â body { background: url('http://www.surrealhosting.com/images/background.jpg') #666 no-repeat fixed center center; } Edited June 22, 2009 by BAJI26 0 Quote Link to comment Share on other sites More sharing options...
silentace Posted June 22, 2009 Author Share Posted June 22, 2009 try changing background postion to : top center  thanks, worked like a champ. Just wondering why i never ran into that issue before. Thanks again 0 Quote Link to comment Share on other sites More sharing options...
