eccen Posted June 15, 2009 Share Posted June 15, 2009 (edited) I am having trouble redirecting to a custom page after client login. I created a custom page based on the documentation (http://wiki.whmcs.com/Creating_Pages) and it loads up fine. However, dologin.php?goto=custom does not work, and it loads to clientarea instead of the custom page I created. I added $_LANG["customtitle"] = "custom"; to my language file as well. What am I doing wrong? I have the latest version of whmcs Edited June 15, 2009 by eccen 0 Quote Link to comment Share on other sites More sharing options...
BAJI26 Posted June 15, 2009 Share Posted June 15, 2009 (edited) dologin.php?goto=[color=red]custom[/color] where 'custom' is the name of the template. Make sure there are't any spaces between $_LANG["[color=red]newtitle[/color]"] = "New Title"; . Edited June 15, 2009 by BAJI26 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted June 15, 2009 Share Posted June 15, 2009 dologin.php?goto=[color=red]custom[/color] where 'custom' is the name of the template. Make sure there are't any spaces between $_LANG["[color=red]newtitle[/color]"] = "New Title"; . Where "custom" is the name of the custom php file... not the template or the page title. 0 Quote Link to comment Share on other sites More sharing options...
BAJI26 Posted June 15, 2009 Share Posted June 15, 2009 My bad! Thanks Sparky! 0 Quote Link to comment Share on other sites More sharing options...
eccen Posted June 15, 2009 Author Share Posted June 15, 2009 Hmm... I still can't get it work. What am I doing wrong? Thanks! Here is my code: login form <form method="post" action="/account/dologin.php?goto=pw_create"> <input type="hidden" name="token" value="---tokencode---" /> Email Address: <input type="text" name="username" size="50"><br> Password: <input type="password" name="password" size="20"><br> <input type="submit" value="Login"> </form> (whmcs root)/pw_create.php <?php define("CLIENTAREA",true); require("dbconnect.php"); require("includes/functions.php"); require("includes/clientareafunctions.php"); $pagetitle = $_LANG['pw_createtitle']; $pageicon = "images/support/clientarea.gif"; $breadcrumbnav = '<a href="index.php">'.$_LANG['globalsystemname'].'</a>'; $breadcrumbnav .= ' > <a href="pw_create.php">pw_create</a>'; initialiseClientArea($pagetitle,$pageicon,$breadcrumbnav); if ($_SESSION['uid']) { # User is Logged In - put any code you like here } # To assign variables in Smarty use the following syntax. # This can then be used as {$variablename} in the template # Define the template filename to be used without the .tpl extension $templatefile = "pw_create"; outputClientArea($templatefile); ?> and added $_LANG["pw_createtitle"] = "pw_create"; to (whmcs root)/lang/English.txt 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted June 15, 2009 Share Posted June 15, 2009 remove the underscore from all instances of "pw_create" eg.. make it "pwcreate" 0 Quote Link to comment Share on other sites More sharing options...
eccen Posted June 15, 2009 Author Share Posted June 15, 2009 remove the underscore from all instances of "pw_create"eg.. make it "pwcreate" Ah problem solved! Thanks a lot! why does the underscore cause the problem? I guess it thinks the underscore is a space? 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted June 15, 2009 Share Posted June 15, 2009 I believe only numbers "0-9", letters "a-z" (upper or lower case), and from some tests "-" is the only characters allowed in the file name. 0 Quote Link to comment Share on other sites More sharing options...
