sohouk Posted August 12, 2010 Share Posted August 12, 2010 This workaround is OK, but I had problems with it. Firstly, its not too clear in the text file exactly where the information (API key etc) goes (its in the section around line 130). You also need to set the Test mode to yes or no (not mentioned in the dox) It seems to me that as the WHMCS implementation of OpenSRS is fundamentally broken when it comes to existing (imported) domains that they should work on something like this php script and incorporate it into their core code. 0 Quote Link to comment Share on other sites More sharing options...
windwaterwaves Posted August 13, 2010 Share Posted August 13, 2010 Wow.. this was fun.. First.. the file download is RAR so you have to download it, rename it from zip to rar, then on your linux box, install unrar (yum install unrar), then unrar x stupidmodule.rar. Do it from in the modules/registrars dir it will create the correct dir itself.. Now edit the file go here function opensrsexisting_getConfigArray() in this section is where you put in your opensrs username and keys, change testmode to yes, or no. After all that.. it just hoses the domain name, loses the screen in whmcs, so you have to use sql to remove the record... So.. dont' bother 0 Quote Link to comment Share on other sites More sharing options...
billchalmers Posted August 15, 2010 Author Share Posted August 15, 2010 (edited) Here is an update of the code which fixes a lot of the above bugs, again - this may work for some of you and not for others, I am using it successfully at the moment but you are using this at your own risk, as with everything backup first! opensrsexisting.zip Edited August 15, 2010 by billchalmers 0 Quote Link to comment Share on other sites More sharing options...
sohouk Posted August 16, 2010 Share Posted August 16, 2010 Wow.. this was fun.. First.. the file................So.. dont' bother The mod Bill provides does appear to work (for me) – and he has to be credited with so much of the hard work that has gone into it. It took me quite a while to get it going simply because the dox were not clear at all how things should be set up and it took ages sorting it all out largely because I didn’t really know what I was supposed to be doing. As you point out, even from the get go, its not a simple zip file you have to deal with! If WHMCS didn’t use a unintelligent system with OpenSRS registered names then Bill would not have had to produce what he has. 0 Quote Link to comment Share on other sites More sharing options...
astralinterne Posted March 15, 2011 Share Posted March 15, 2011 (edited) Everything is working fine exept when an invoice get paid and the renew should be done automatically. I get this error: Client has paid for the renewal of domain XXXXXX.XXX and the automated renewal attempt has failed with the following error: Current expiration year must be specified. Any ideal of what's wrong with the code? (By the way, the current expiration date in my WHMCS is the exact expiration date. So I dont know why I'm getting this error) Edited March 15, 2011 by astralinterne 0 Quote Link to comment Share on other sites More sharing options...
sohouk Posted March 15, 2011 Share Posted March 15, 2011 I can't solve your problem, but you need to be aware that WHMCS does now have a fix for Open SRS domains. Its tucked away and not detailed very clearly. The official doc is here: http://docs.whmcs.com/OpenSRS#Importing_Domains The mention of the solution is easily missed (it’s under the Importing Existing Domains section) and is really very thin on the practical steps you need to do. Here what you have to do: You create a table called ‘mod_opensrs’ in your WHMCS database, and use it to store your OpenSRS username and pass for each domain. You go to PhpMyAdmin, find the WHMCS table and create the new table there using this command. CREATE TABLE `mod_opensrs` (`domain` TEXT NOT NULL ,`username` TEXT NOT NULL ,`password` TEXT NOT NULL) When its created, populate it with the relevant domain, username and password When that is done you will find the following will work: Register Transfer Renew Registrar Lock Update Nameservers Update WHOIS EPP Code The following do not work Register Nameservers DNS Record Management Email Forwarding This saved us a huge amount of work as we had imported a lot of OpenSRS domains and whilst other solutions were partly successful, there were snags with both of the working methods. Trevor 0 Quote Link to comment Share on other sites More sharing options...
whatevercomputes Posted March 17, 2011 Share Posted March 17, 2011 I can't solve your problem, but you need to be aware that WHMCS does now have a fix for Open SRS domains. Its tucked away and not detailed very clearly. The official doc is here: http://docs.whmcs.com/OpenSRS#Importing_Domains It might be nice to point out that this feature was added in v4.4.2 which could save someone trying to use it with v4.4.1 a ton of time. :-( It would also be nice to hear from someone official whether there are plans to integrate the management of this table into WHMCS so I could know how much effort I should put into developing a solution for that. Anyways, thanks a whole bunch, sohouk, your post was key to solving this. -srw 0 Quote Link to comment Share on other sites More sharing options...
dahamsta Posted August 10, 2011 Share Posted August 10, 2011 I can't solve your problem, but you need to be aware that WHMCS does now have a fix for Open SRS domains. Thanks for this sohouk, I had no idea this existed. +1 to whatevercomputes' request for an interface to this. adam 0 Quote Link to comment Share on other sites More sharing options...
kenwardc Posted February 18, 2012 Share Posted February 18, 2012 Hi Folks I'm using the latest version of WHMCS and still getting the Authentication error when I go to the summary of any OpenSRS domain. Does anyone know whether the fix above is still something we need to do for all domains or whether there is a new trick we can use to get around the problem? Cheers Chris 0 Quote Link to comment Share on other sites More sharing options...
sohouk Posted February 18, 2012 Share Posted February 18, 2012 I have not seen anything in the docs to say that the facility is built into v5 so I would guess its safe to assume that you still need to use the Open SRS workaround by adding the new table. Trevor 0 Quote Link to comment Share on other sites More sharing options...
kenwardc Posted February 18, 2012 Share Posted February 18, 2012 Hi Trevor So for this new table - does it mean we have to enter every domain on the system, with its username and password into the database table, thereby duplicating all the work? My goodness - what about those of us with thousands of domains registered to our customers? Cheers Chris 0 Quote Link to comment Share on other sites More sharing options...
billchalmers Posted February 19, 2012 Author Share Posted February 19, 2012 Hi Trevor So for this new table - does it mean we have to enter every domain on the system, with its username and password into the database table, thereby duplicating all the work? My goodness - what about those of us with thousands of domains registered to our customers? Cheers Chris Yes, that's what we have had to do. 0 Quote Link to comment Share on other sites More sharing options...
sohouk Posted February 19, 2012 Share Posted February 19, 2012 Yes, you do need the new table. If you already have all the user-names and passwords in a table, then it should be easy enough to import them into the WHMCS database as a table. Trevor 0 Quote Link to comment Share on other sites More sharing options...
kenwardc Posted February 19, 2012 Share Posted February 19, 2012 Gotcha - OK - I've added the passwords for one or two domains and it works fine. Thanks all! 0 Quote Link to comment Share on other sites More sharing options...
nmadafeoajead02 Posted February 21, 2012 Share Posted February 21, 2012 I too am getting this error. Communication between the server and the Tucows API is successful. Any ideas 0 Quote Link to comment Share on other sites More sharing options...
kenwardc Posted February 21, 2012 Share Posted February 21, 2012 Hi there, nmadafeoajead02 it seems the solution we've discussed above is the only one that's valid at the current time. The way I solved it on my system is as follows: I installed phpMyAdmin on my server and made sure it's not accessible by anyone but me. Once installed I logged in and had a look at the WHMCS database. Go to the table called mod_opensrs and click Insert As a test, enter one of the domains you've added manually, with its password and login Click the HOME button in phpMyAdmin once you have saved the table data Click Privileges and then click Reload The Privileges to restart phpMyAdmin Go back to WHMCS and select the domain you've used. Change the nameservers as a test to something else. All should be OK without the Authentication error. Change the nameservers back to what they should be a re-save the domain entry, It's a pain in the b*m but it works! Cheers - hope that helps. Chris 0 Quote Link to comment Share on other sites More sharing options...
rlservices Posted November 30, 2012 Share Posted November 30, 2012 We're now November 2012 and the solution above is still the only way to import existing domains. The page here (http://docs.whmcs.com/OpenSRS#Importing_Existing_Domains) really should be updated to point at least to this forum post. I don't know how much time I spent trying to find the table until I googled the issue and found this post and realized I had to create the table myself! Roch Lambert 0 Quote Link to comment Share on other sites More sharing options...
JonTheWong Posted April 11, 2013 Share Posted April 11, 2013 I've tried the adding the sql statement to my system and i've inserted the domain/user/password combo and i'm still unable to get it to work. Unable to lock/unlock can't update NS server. Can't update contact info or receive EPP code. Also its worth nothing that i'm using the OpenSRSPro module supported by OpenSRS (https://opensrs.com/site/integration/tools/whmcs) I have not tried using the default module since OpenSRS actively supports there module. 0 Quote Link to comment Share on other sites More sharing options...
hostmx Posted April 8, 2014 Share Posted April 8, 2014 Los archivos que baje no me funcionaron bien, tuve que hacer convinacion de archivos dejando solo opensrsexisting.php y los demas archivos del original de opensrs, active el proveedor de dominios, cambie el proveedor en el dominio y active el ID de suscripción manejando el usuario/password y funciono corrrectamente 0 Quote Link to comment Share on other sites More sharing options...
hostmx Posted April 8, 2014 Share Posted April 8, 2014 Esta es la mejor forma, funciona perfectamente Muchas gracias 0 Quote Link to comment Share on other sites More sharing options...
