Methinks Posted May 24, 2009 Share Posted May 24, 2009 Since installing v4 which is great by the way. My portal page has changed and not for the better. I can use the old portal but loose some functionality. KB Articles just loop back to categories and never show the actual article. If I use the portal that comes with the new install I loose my header which has my live support in it. If I try to use my header in the top of the page it breaks the whole page up terribly. How can I merge these two files or how can I get KB articles to show up on the original portal. This would be the best answer as my customers are used to and like the old portal system. Any help appreciated thanks Jeff 0 Quote Link to comment Share on other sites More sharing options...
hightekhosting Posted May 24, 2009 Share Posted May 24, 2009 In all honesty, your best option is to work to modify the new theme/template to suit. It obviously will take some redesign and time to complete, but it's an option your really not going to avoid. 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted May 24, 2009 Share Posted May 24, 2009 You'll need to update the template, it's changed in the new version: http://wiki.whmcs.com/Version_4.0_Release_Notes 0 Quote Link to comment Share on other sites More sharing options...
