madriguera Posted May 7, 2009 Share Posted May 7, 2009 Hi, I upgrade my system whmcs to the new version 4.0 but after of this upgrade i notice a problem with the language spanish with the next characteres: ´and ñ , if you check in my website when i have the system http://www.lamadriguera.net/clients/ the characters ´and ñ doesnt appear correctly it show the next way: "Ãrea del Cliente", "aquÃ", etc.. In the last version 3.8.2 i dont have this problem. 0 Quote Link to comment Share on other sites More sharing options...
VS-fam Posted May 8, 2009 Share Posted May 8, 2009 (edited) Go to your general settings -> localisation and change the charset option to iso-8859-1. That should fix it Edited May 8, 2009 by VS-fam 0 Quote Link to comment Share on other sites More sharing options...
madriguera Posted May 8, 2009 Author Share Posted May 8, 2009 Hi, Thanks i change that and my problem is fixed. 0 Quote Link to comment Share on other sites More sharing options...
bolhost Posted May 22, 2009 Share Posted May 22, 2009 Hi there; I have the same problem but I have the codification iso-8859-1 on the localisation settings.... any idea? Regards 0 Quote Link to comment Share on other sites More sharing options...
mozart7 Posted June 10, 2009 Share Posted June 10, 2009 Sem problem, I already change to iso-8859-1 but the problem has returned any ideas? 0 Quote Link to comment Share on other sites More sharing options...
ardase Posted June 25, 2009 Share Posted June 25, 2009 a mi tambien me pasa como a ti Mozart7 , alguna solucion?? Sem problem, I already change to iso-8859-1 but the problem has returned any ideas? 0 Quote Link to comment Share on other sites More sharing options...
blymp Posted October 29, 2009 Share Posted October 29, 2009 You guys need to change the codification on the template (.tpl) files. The codification of the .tpl files by default is different from ISO-8859-1. To change open your .tpl file and save as... with the right type. 0 Quote Link to comment Share on other sites More sharing options...
