elitbir Posted April 10, 2009 Share Posted April 10, 2009 (edited) Website : http://www.qtechnics.net/QWHMCS The new version has been published. I try to restart the program or is enough to QUpdate. Important Please file qapi.txt and qapi.php do not forget to update your whmcs include folder. Please donate to the project's benefits. Donate PayPal v 1.0.0.0 First Version Release. v 1.2.0.0 QUpdate - Update system integration Program Setting Panel included Some bug fixed v 1.3.122.34 Ticket Viewer Added Ticket Response Viewer Added Ticket Reply Added (API required.) Main window style changed Some bug fixed v 1.4.123.76 Mysql requirement was removed. Communication between WHMCS and QWHMCS to qapi.php was created. A few translation errors corrected. v 1.5.126.34 Closing Ticket is completed. "Root Line 0" error was resolved. Theme support added. Added In Progress and On Hold ticket status. Some errors were corrected. Edited April 10, 2009 by elitbir 0 Quote Link to comment Share on other sites More sharing options...
danield Posted April 11, 2009 Share Posted April 11, 2009 How safe is this? because we have to enter our sql details. 0 Quote Link to comment Share on other sites More sharing options...
danield Posted April 11, 2009 Share Posted April 11, 2009 Is there any other way to do this without entering our SQL info? 0 Quote Link to comment Share on other sites More sharing options...
wsa Posted April 11, 2009 Share Posted April 11, 2009 ElitBir.Net Internet Solutions I send you a email with some bug 0 Quote Link to comment Share on other sites More sharing options...
FazeWire Web Services Posted April 11, 2009 Share Posted April 11, 2009 When I try and download the software, all I can ever get is the 1.2 version. I have tried clearing cookies, cache, even using a proxy. Do you have a direct link to the newest .exe file? The qUpdate thinks I have the latest version as well. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 11, 2009 Author Share Posted April 11, 2009 How safe is this? because we have to enter our sql details. Hi, The program is completely open source. The source of all programs must be qapi.php need for all the links QWHMCS site is available in the google code page. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 11, 2009 Author Share Posted April 11, 2009 Is there any other way to do this without entering our SQL info? version 1.2 of SQL information required. QUpdate update the program, 1.5 version will need the information for the mysql. In this work safely qapi.php on the server side was prepared to do. php files and database connection include WHMCS is the self. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 11, 2009 Author Share Posted April 11, 2009 When I try and download the software, all I can ever get is the 1.2 version. I have tried clearing cookies, cache, even using a proxy. Do you have a direct link to the newest .exe file? The qUpdate thinks I have the latest version as well. We update the web server probably do not because of their misbehavior. periodically try again. We currently are running stable. Thank you 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 11, 2009 Author Share Posted April 11, 2009 Thoughts about the security ones. Write the program is completely open source. Who want a compiler can compile again. You can access the source code from the following site. http://code.google.com/p/qwhmcs/source/browse/trunk/QWHMCS/ The source code is sold as a commercial plug-ins are confidential, although people do not consider security issues in open source software do not understand this thinking. Regards. 0 Quote Link to comment Share on other sites More sharing options...
flip Posted April 16, 2009 Share Posted April 16, 2009 Are there any plans for making this compatible with 3.8.1? And not just 3.8.2? 0 Quote Link to comment Share on other sites More sharing options...
FazeWire Web Services Posted April 16, 2009 Share Posted April 16, 2009 Are there any plans for making this compatible with 3.8.1?And not just 3.8.2? Why would you be running 3.8.1? 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 17, 2009 Author Share Posted April 17, 2009 Are there any plans for making this compatible with 3.8.1?And not just 3.8.2? Hi, In fact, all of the 3.8.x version 3.8.2 works, but I had made so hard. If you'd like to change the appropriate line in the file qapi.php version 3.8.1 can work. Find this line; if($major==3 && $minor==8 && $revision<2) { die("If your version of WHMCS old. Minumum version 3.8.2 is required."); } This change; if($major==3 && $minor==8 && $revision<1) { die("If your version of WHMCS old. Minumum version 3.8.2 is required."); } Regards. 0 Quote Link to comment Share on other sites More sharing options...
Kurogane Posted April 17, 2009 Share Posted April 17, 2009 I have a problem, when i trying to connect QWHMCS connects and in the bottom say 'ok', and shows me all is alright. But only shows me a blank page in all tabs and nothing happens i have several tickets open and closed I'm accessing using admin access. What is causing this problem? Thanks You. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 17, 2009 Author Share Posted April 17, 2009 I have a problem, when i trying to connect QWHMCS connects and in the bottom say 'ok', and shows me all is alright. But only shows me a blank page in all tabs and nothing happens i have several tickets open and closed I'm accessing using admin access. What is causing this problem? Thanks You. Check the following; 1 - qapi.txt file in the directory includes qapi.php establishment of the WHMCS folder have installed? 2 - Your WHMCS version 3.8.2? 3 - API user information entered by the user in the Class Manager API selected in settings? Regards. 0 Quote Link to comment Share on other sites More sharing options...
Kurogane Posted April 18, 2009 Share Posted April 18, 2009 1. What you mean? i need to upload two files? qapi.txt in /home/user/whmcs/include and qapi.php in /home/user/whmcs/ ? but the program only create me a qapi.txt where i can find qapi.php. 2. Yes 3. I select user admin for this, if this correct so then, yes 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 18, 2009 Author Share Posted April 18, 2009 1. What you mean? i need to upload two files? qapi.txt in /home/user/whmcs/include and qapi.php in /home/user/whmcs/ ? but the program only create me a qapi.txt where i can find qapi.php. 2. Yes 3. I select user admin for this, if this correct so then, yes Last updated by QWHMCS you must create a file on your desktop qapi.txt name. Change the file extension as php. This file in the folder where you installed WHMCS includes the upload folder. For example; /httpdocs/whmcs/includes/qapi.php Once you make this process must work as seamlessly. 0 Quote Link to comment Share on other sites More sharing options...
Kurogane Posted April 19, 2009 Share Posted April 19, 2009 I'm already done that is why i have ok on the program but not show me nothing. 1. In the first image you see i select closed tickets to show me some info and not give me nothing happend in all tabs. 2. The second image is the settings i have of course http://www.domain.com/whmcs is a example. Thank You 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 19, 2009 Author Share Posted April 19, 2009 I'm already done that is why i have ok on the program but not show me nothing. 1. In the first image you see i select closed tickets to show me some info and not give me nothing happend in all tabs. 2. The second image is the settings i have of course http://www.domain.com/whmcs is a example. Thank You Then you have to test to the manual. Md5 passwords are encrypted as WHMCS. This is why we need to do MD5 password first. At the following address to your password MD5 transform. http://www.bilgiportal.com/md5.php Then according to the following example by editing your browser's address bar type. http://www.domain.com/whmcs/includes/qapi.php?action=4&user=yourusername&passwd=yourmd5password&rand=1234 The rand each variable in your experiment, use of random numbers that does not make your browser cache. As a result, the XML must come in the form Closed Tickets. If you receive error messages that tell me what the question is should I work to find. 0 Quote Link to comment Share on other sites More sharing options...
Kurogane Posted April 19, 2009 Share Posted April 19, 2009 (edited) action=4 Error reading XML: syntax error Location: http://www.domain.com/whmcs/includes/qapi.php?action=4&user=Administrator&passwd=83bb7355a52055b3e3990550064555e4&rand=1234 Number of line 1, column 1: No Record ^ action=3 Error reading XML: syntax error Location: http://www.domain.com/whmcs/includes/qapi.php?action=3&user=Administrator&passwd=83bb7355a52055b3e3990550064555e4&rand=12345 Number of line 1, column 1: No Record ^ action=2 Error reading XML: syntax error Location: http://www.domain.com/whmcs/includes/qapi.php?action=2&user=Administrator&passwd=83bb7355a52055b3e3990550064555e4&rand=12346 Number of line 1, column 1: No Record ^ Edited April 19, 2009 by Kurogane 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 19, 2009 Author Share Posted April 19, 2009 According to the well seems to have no tickets qapi. Interesting. will contact me via MSN do. http://eb.net.tr/mail.jpg 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 20, 2009 Author Share Posted April 20, 2009 With the problems we found a bug Kurogane. From customers that are not registered QWMCS version does not list tickets. Following publication of the new version until this issue can be resolved by making changes. qapi.php file; line 120 find: $query = "Select tbltickets.*,tblticketdepartments.name AS d_name,tblclients.firstname AS u_name,tblclients.lastname AS u_subname FROM tbltickets Inner Join tblticketdepartments ON tblticketdepartments.id = tbltickets.did Inner Join tblclients ON tblclients.id = tbltickets.userid $wherestr ORDER BY DATE DESC"; Replace this: $query = "Select tbltickets.*,tblticketdepartments.name AS d_name,tblclients.firstname AS u_name,tblclients.lastname AS u_subname FROM tbltickets Left Join tblticketdepartments ON tblticketdepartments.id = tbltickets.did Left Join tblclients ON tblclients.id = tbltickets.userid $wherestr ORDER BY DATE DESC"; And save. Report this to bug you, thank you Kurogane. 0 Quote Link to comment Share on other sites More sharing options...
Kurogane Posted April 20, 2009 Share Posted April 20, 2009 Hey no problem elitbir. I'm glad you've fixed the bug. Nice Program Regards. 0 Quote Link to comment Share on other sites More sharing options...
